Did the edge finish on the gap covers, put them in place then fussed around with further bending until I had a good fit. Following plans they installed one at a time and drilled #40. Lori helped me drill. Got the empennage fairing out and did the edge trim to 1/8" from scribe line then it was on and off a dozen times while sanding high spots. Finally got an acceptable fit, will drill tomorrow
