Van's builder support says the CherryMax rivets will be fine, and to use MSP-42's down in the corner where I can't get a straight pull on the CM's. Turns out CR3213-4-2 is the correct size and I had enough of them here to fill the holes. Also used 2 MSP 42's and 2 470AD4-5's. All is well again. Finished riveting shroud ramp to sides. Ordered replacement rivets from Aircraft Spruce. Installed forward center section bulkhead. Bolted and riveted it to the tunnel cover. Lori and I riveted the rib flanges to the bottom skins. Made up heat ducts and vent arms. Began riveting rib covers and nut plates.
