Tedious fitting and adjustments. Needs a minor change in some small angles and ready to paint & rivet.
Raised the front of the plane and inserted the nose gear, and tightened the bolt/nut. Without the engine, the aft CG requires support under the tail.
Finally removed the 'painters tape' from the aft fuselage, used to protect the skin from the VS fairing. A little Goo-Gone and elbow grease, then some polish cleaned it up.
Other misc tasks, then some hangar flying to test controls.
