RV-6A - GBC
Date:  6-16-2017
Number of Hours:  3.00
Brief Description:  Nose Gear - Pant added
Lot of fiberglass sanding, grinding, cutting and R&R tasks. Finally shaped and aligned enough to match-drill the mounting holes and then added the holes for the 'tow bar' and also the axle access. Need to add extension and hole for air valve access.
A little rattlecan primer to keep it protected briefly from UV deterioration, but need to design a paint scheme and finalize that.
Evil Tuna ??
Evil Tuna ??
