Made an adaptation on the Cabin Heat control cable, which has been tethering the panel (preventing its removal). Cut a slot in the edge edge (flange) of the panel and removed cable, then fabricated a bracket that will attach behind the panel for complete removal when needed.
Last chance to remove the panel and secure harnesses, and document before it is finalized.
Added Adel clamps for alternator power cable, and the ANL 60A firewall-mount fuse for the alternator output.
