Unbundled and re-routed each section of each harness to be sure that it was not twisted, or wrapped around another. Added a cross-member to the 2 angle supports and a small hinged sheet to secure the 'switch ground block' and the terminal strip from the FWF engine sensors. These will be added to secure them.
Need to finish the re-bundling and security of the harnesses. Need to shorten a couple of lighting circuits wires and re-terminate them.
