Brief Description: VP-X - more testing and adjustments
Swapped switches to new mounting strip, and configured a laserprinter strip of labels. Appears that 1" on-center is about right but would like a slight increase between functions of similar switch functions, example group all the LIGHTING switches at 1" but 1.125" between these and the other functions.
Added the WigWag switch to the configuration and tested with Taxi & Landing Light pulsing, but also had a possible problem because turing OFF WigWag didn't stop the pulsing. Only turning OFF both the TAXI and LAND switches stopped the pulsing. Need to re-test and investigate this.
Also setup a small PC heatsink and fan for possible use in the panel glareshield to move air, or as aux fan on the iPAD mount.
Switch panel is a test only - to be finalized in .063 sheet. Also need to add nutplates to allow this panel to be removed from the back side of the instrument panel.
