Fabricated a mounting plate for the Vans LED to be located in the baggage area but will pan & tilt to provide general cabin illumination, too.
The LED is a high grade A/C alum anodized light fixture. Attached it to a STSP switch and terminated with ground ring, and Fast-ons. Also added sufficient power lead to reach the subpanel for "interior light" power.
Misc - located, trimmed length, traced and tagged the SV-NET harnesses from the aft compartment to the subpanel. Will have to terminate, label, and securely route later.
