Toned out the switches on the Tosten grip, Reviewed possible functional assignments, layed out the connector pin-outs for each switch. Fabricated to sets of wire to extend the Tosten leads to the instrument panel (subpanel) connections. The harnesses (one for pilot, one for co-pilot) will simple extend the 11 Tosten leads to the subpanel so connections can be made to the SkyView system (SV-1000, Radio, etc).
Need to determine whether HAT switch and other two top switches can be used to control the 'cursor' and 'execute' selections. Trigger will be PTT, and Index button will be AP disconnect.
