Put a nutplate on the web of the rib where the pitch servo mounts. Secured the conduit with an Adel DG12. Need to complete the strain relief, DB9 shell, and shrink/secure the power leads.
Added 2 wire Molex connector to the flap motor and power leads. Need to route the power leads, and secure them. Need to add a panel mount flap actuator switch next.
Fabricated 10 brackets with grommets as wire guides for routing wires in the fuse.
