Brief Description: VP-100 power distribution, switches
Reviewed the many electrical requirements to power all the Dynon components; Intercom, Radio, SV1000, Servos, etc. Also, power requirements within the SV-net network bus. Specific components must be powered outside the SV-net, while others are integral to the SV-net connections (DB9).
More discussions with Glen on the Phone/MIC harness components, common grounds for audio wiring, and various connectors between SV components. Decided to construct an 'audio ground bus' using a DB9 or DB15 to consolidate the leads and feed the PIN 1 connection on the Intercom's DB25.
