Dynon released SW update 15.0.2,, with significant features and also at the same time a 28-day cycle update. Good time to do the update while I can ground test the unit.Hoping that the WiFi to the iPad will support ForeFlight - not confirmed.
Removed the rudder bottom fairing and made the hole adjustments to use Tinnerman washers and replaced the screws with SS #6 C/S.
With the McMaster-Carter weatherstripping on the canopy frame the mechanism is too tight and the linkage is stressed. Removed the right strip and then worked on the left side (files the lug hole). Found 1/8" adjustment required. Right side tighter, will need more.
