Added the nutplates to put the Dynon MAP sensor on the engine side of the FW (per discussion with Dynon) --- actually it is the same component used in automobiles and they are in the engine component.
Fancy termination of wires will wait until the wire is not ging to be moved again. (Routed and secure).
Added the remaining rivets on the FW except for the two under the tight spot below engine mounts.
Added cable mount rough-cut brackets to the instrument panel. Other minor tasks, and some plan reviews.
