One of the recent issues has been the unacceptable low volume of alerts, messages, and warnings from the SkyView EFIS. Audible during ground tests, but so low as to be on no value in the air. AOA tones, for example, too quiet. Increased the Master Volume Control and tested.
Also adjusted the pulses/gal of fuel use, and hope that it will improve the wide difference between the Tank Level sensors and the Fuel Used (flow meter). Changed from 68000 to 60000 as a starting point. Filled the tanks and will top-off each flight to see and adjust the setting.
Also, adjusted the 'trigger' point for AOA audible alerts - used the recommendations from the screen notes at the bottom.
