RV-6A - GBC
Date: 3-28-2016
Number of Hours: 7.00
Brief Description: SV audio output & Finish EMS sensors
Afternoon spent on the termination of FWF sensors (MAP, Fuel Pres, and Oil Pres) and cleaning up the routing.
Evening was configuring the SV Audio Output, which allows SkyView audio alerts aural messages to be heard on the SV Intercom, and overrides others radio and intercom inputs. Don't know why the wiring harness built by SteinAir didn't connect the SV Audio input leads but this required opening the D25 shell on the SV Intercom and to add the sockets for connections (as shown).
EFIS PFD (Brn, Blk, and Gray), pins 13, 30, and 31 connect to Intercom sockets (19, 20 and 6) respectively. Blk is grnd, Brn is Left and Gray is Right audio.
While the panel was removed the subpanel components were secured and wire routing improved.
SV Audio out to SV Intercom
SV Intercom inputs
EFIS D37 to Intercom D25
