Downloaded v14.0 of for the SkyView, and an update to the FAA Obstacle db, and applied power to VP-X to boot and install them. Need to re-config J-4 and J-3 pins for the proper pins (didn't do after the VP-X update from VP-100).
Setup the laptop, and external monitor to talk to the VP-X via Ethernet cable and retrieve pin assignment data. Need to re-check all the Molex connectors, but had enough info to do updates to SW on SkyView.
