RV-6A - GBC
Date:  10-12-2014
Number of Hours:  1.50
Brief Description:  Dynon - harness connectors
Stripped Dynon pitch servo harness wires behind the subpanel. Added 3-conductor Molex for the Pwr/Grnd/Disengage, and a D9(F) to the SV-NET pairs. Need to add Pwr/Grnd/Dis extensions to their appropriate connection points, and wire in the Disengage to the control stick switches (with possible panel mount button option).
Discovered that I had used SV-NET Servo harness to the ADAHRS and need to remove and replace with proper ADAHRS version of harness wires.
Added two tiewrap anchors to the right side panel bulkhead with blind rivets to secure the harness conduit.
Roll servo harness connectors
Tiewrap anchor
Tiewrap anchor
