RV-6A - GBC
Date:  7-31-2014
Number of Hours:  2.20
Brief Description:  ADAHRS - mount
Fabricated a light weight tray for the Dynon ADAHRS for the Sky View, on the rails behind the baggage bulkhead.
Tray has four sides bent down and the front and back slip over the rails to physically secure the tray before rivets. Will attach the tray to the rails with AL rivets to avoid ferrous fasteners and use brass or plastic to fasten the ADAHRS to the tray. Mount carefully positioned to also ensure that alignment with all 3 axis of aircraft is established and maintained.
Tubing for the 3 functions; AOA, Pitot, and Static pressure, will be fed from the bottom up to minimize any condensation entering the ADAHRS by gravity. Service loops will also be used.
Roughed in fit
Roughed in fit
Fabricated result
Fabricated result
