After a long and much interrupted night effort, I had the energy to finish the filing of the Vertical Power (VP-100) power control panel opening. This is the switches and power status display with remtoe electronic breakers. It is the bus control with a separate 'blackbox' mounted under the forward area of the subpanel. That component is the actual electronics, while the VP-100 panel is the control head.
The remote piece has all the wiring harnesses for power, ground, and breakers, and mounts on a swing-down detachable hinge.
There is enough panel space on the left side for the full PFD (Dynon SkyView 10") and an optional secondary SV 7 or 10" on the right.
