Worked on fabrication design for the ADAHRS mount, in the aft fuselage aft of the baggage bulkhead.
Mounted SV-OAT in the rear fuselage under the Rt-HS area. Routed wiring to the area where the ADAHRS will mount.
Preliminary Static/AOA/Pitot hose routing and grommets. Ordered AirSafe blue tubing to finish the AOA air supply. (Avery) - arrived today. Need to order 90deg tubing fittings.
Tested a platform for ADAHRS but too close to pitch servo. Need to re-think the separation.
