Fabricated the wire harness for the Starting Vibrator, and connected the P-Leads, and SV to the Ignition switch. Rotated the prop manually with plugs removed and starter disconnected.
With ignition switch in the "start" position, the SV on the #1 plug produces the 'shower of sparks' as needed.
Rest is setting and sync'ing the mags, fine tuning.
