Added the Adel clamp and custom L-bracket to Red Cube, attaching to the engine mount. Reverted to a previous version of the throttle cable bracket and moved cable attach to the 'shorter arm' position.
Have not removed 'caps' from the servo (AFP FI) at this point but will have to remove and drain preservative oil.
Adel clamp on the servo output to FI fuel distribution hose, and again have to remove cap and drain preservative oil.
Adjusted throttle cable for idle cut-off, and WOT positions to ensure full range of travel.
