Used a 1/4" brake line hose (temporarily) to confirm fit, routing, of fuel line needed for FI servo to the top of enigne (nozzle distribution) ... using flexible hose and segment of aluminum line. (VA-118-1 is right length).
Moved the Red Cube to new position after final tweaking on the throttle cable bracket. Better routing and moves transducer closer to right side of FI servo. Changes the that hose design.
Added exhaust pipes to check the clearances and hardware.
Riveted the NACA vents, finally. Added the 2" hoses but need to finalize.
