New Kelly Aerospace ignition wiring harnesses arrived from Spruce. Shot in the dark on the right lengths when ordering, but it looks close and workable. Top side will require a proper routing, through the baffles and grommets.
Attachment to the clips on the intake tubes will keep the bottom side tidy and secure. The overall is good.
Worked on cleaning up some dust & rain that splashed on the wing cart and planning the assembly areas, tables, and tasks for final steps.
Ordered some additional intake gaskets, P-Leads, grommets, and fasteners for the engine work.
Inserted studs in the sump, with Locktite (Blue) --- let it set up before further fastener work.
