Installed the Fuel Divider for the AFP Fuel Injection (FM-150). Preliminary fit and then begin the injectors, and feed lines to them. After careful review, got out my 1/8" NPT 27 tap and chased the injector threads to clean out the old pipe goop used on the plugs. (With the intake tubes OFF, any debrids falls through the opening intake ports to the floor.)
Problem with the length of the bolts for the flow divider bracket (due to baffle bracket thickness), and interference with the engine hoist ring, which can be removed but not yet).
Had to research and order the throttle control and mixture control cables, and then the attach plate for them in three places; under the instrument pane, subpanel, and sump.
Still inestigating the exact location of the FW holes for the cables, and which eyeball to use for them.
