Slight trimming, and fitting the brackets that attach to the case, under the engine - i.e., inboard side of the front sections.
Lift the bottom cowl into position to compare the inlet vs the baffle ramps. The cowl will need some fiberglass work to extend and straighten the relationship, especially on the left inlet.
Almost ready to disassemble, clean and prime the front two sections. Will then do the final assembly (rivet).
