More trimming on the aft panels, especially the left. The aft panels were not as close to perfect as the other three sides, but actually worked up better than expected. The difficulty is that each little trim shifts the panel slightly (removes the interference) and then a little more needs to go.
Mainly the two engine mounts needed to pass through the panels, and the left side needed to be trimmed around the top of the case. Otherwise the most difficult will be the bracket on the lower right aft panel, tight fit.
Alignment of the 4" oil cooler tube will be less difficult than expected, too. Front ramps tomorrow ...
