Not a huge accomplishment but it's 'pounding rivets' -- one at a time.
Drilled out a FW rivet and attached a nutplate for mounting the retainer clamp for the engine breather tube. (should have the tube on Monday from Vans).
Put a little dirt on the equipment data tag for the alternator to read the s/n and model more clearly. Kelly Aerospace - 12V/60A S/N = H021441 P/N - ALY-8520LS Aircraft Spruce shows as "Belt driven/Blast tube, LS=NewUnit/No Pulley"
