RV-6A - GBC
Date:  8-17-2015
Number of Hours:  3.50
Brief Description:  HS - Fairing attach prep
Drilled and dimpled the HS for the 'new' fiberglass fairings. And countersunk the fibersglass to match, but the edge distance is marginal and will require a metal backing or additional fiberglass reinforcement.
Now need to glass-in the open back side of the fairing to finish this up before riveting on with CS4-4 pull rivets.
Right HS fairing -
Right HS fairing -
Test fit CS4-4
Test fit CS4-4
