Brief Description: Research - P/N's and various tasks
Spent hours and hours, on the internet, researching parts to complete various tasks. For Example; O-360 Sump Gasket. $5.16 but hours to find the right P/N, the source was easy after that.
The SkyTec starter should apparently have a jumper between these two terminals, but what gauge? (It was removed in the helicopter configuration.) (see 9.2.13 -- added jumper)
The cotter pin in the Conical Engine mount doesn't seem to be possible unless maybe the supplied washer is too thick? Can it be changed? or Is the bolt too short? or the torque not enough? Lots of research to get information to meet specs. [UPDATE - removed small washer, cotter pin good. Instructions to tighten and not to a torque spec.]
