Moved more of the engine parts to the hangar, some clean-up, and organizing. Also took the roll-around engine stand.
Reviewed FW tasks possible now with engine removed. Might order the 11 x12 inch Stainless Steel plate to cover the FW/Oil Filter recess and return it to flat configuration will have to do some other tasks affecting the heater distribution box if this is done.
One problem is being able to move the rudder pedal control tubes forward, which it cannot do with the recess. Being tall this is still a consideration. Looked at the position adjustments and viability.
