Lot of fiberglass sanding, grinding, cutting and R&R tasks. Finally shaped and aligned enough to match-drill the mounting holes and then added the holes for the 'tow bar' and also the axle access. Need to add extension and hole for air valve access.
A little rattlecan primer to keep it protected briefly from UV deterioration, but need to design a paint scheme and finalize that.
