After the top skin flox cured on the port side, all of the wood was removed. This did not go exactly as planned. I evidently placed too much bondo and it did a fair amount of damage to the foam in localized positions. I have cut out the foam where it is damaged in preparation of adding new foam.
The leading edge was sanded to shape. The joint to the center spar was sanded so that it is an even surface. There will be a need for sime flox to fill in some gaps.
