The canopy latch required a torque tube to be run near the top of the seat back. In order to protect it from knees and other damage, a cover is being fashioned. In order to attach this cover, a bracket was formed that will attach using flox to the back of the seat and have a vertical flange the will allow fastening of the cover. A piece of urethane foam was shaped into the bracket and two ply BID was layed up over the two brackets. They were peel ply'd and left to cure.
