The front thigh supports have been completed for a long while; however, the fuel lines were run righ in front of the lower section of the Instrument Panel. To cover this up, the front thigh supports was extended. To support the extension, a partial bulkhead was installed in front the fuel line and the brake line. A fiberglass flange was layed up and attached to the bottom floor. The bulkhead was fit with nutplates and is attached to the fiberglass flange with bolts.The thigh support was modified to extend over this new bulk head.
