I cleaned up the edges of the layup from yesterday. I drilled the holes for the camlock posts. I floxed in the two supports in the middle of F28 and the one in the middle front. I am waiting on the other posts to make sure they line up. I may have to get longer posts.
I also made a precautionary repair to the canard. While sanding the foam to shape, I must have sanded the canard surface and it dug into the top glass layer slightly. I layed up one UND to cover this.
I also finished installing the camlocks on the ballast door and the nose gear door. They are finished.
