Brief Description: Laying Up Canopy Hdwe Reinf. and the Inside Skin
I cutoff most of the exposed slumped layup on the copilot side. I then used a belt sander to remove the damaged layup. I left about .3-.5 inches that had cured normally. I removed the damaged foam about 2" around the hard point and up to the edge of the canopy. I formed some new foam for replacement.
