The rods painting was finished and each piece riveted together with Stainless Steel rivets (18-8 stainless steel blind rivets from McMaster Carr, 1/8" dia). During assembly, I discovered that I had not assembled some of the aurora bearings correctly on the wing. Some of the bolts were facing down and some were on the wrong side of the washer. All was fixed and assembled. The starboard aileron crank brackets were installed a little too close to each other. There is some rubbing that will need to be corrected.
