Brief Description: Assembly of Pitch and Roll Parts
10/11/2008 I drilled and mounted the bearings to CS108 and CS118 using AN3-6A bolts. This is a slight change from plans which call for AN3-7A bolts. The aluminum bearing must be thinner than the phenolic bearing. I flox'd the pilot side CS108 and CS118 in position w 10/18/2008 I realized that I had not measured the W.L. of the CS118 bearing properly, so off it comes. I remeasured and floxed both pilot and copilot bearings in. 10/20/2008 I cleaned up the bearing blocks and layed down 2 BID on each side using flox to radius the corner. I peel ply'd the result 10/28/2008 I cleaned up the bearing block supports and reinstalled all of the torque tubes
