Brief Description: Fabrication of Pitch and Roll Parts
08/25/2008 I cut several of the tubing pieces to length. All of the aluminum with the exception of CS-102 is cut. I still need to cut the steel tubing. 09/21/2008 I fitted the pilot side control system together on the bench and started to drill the bolt holes. More to go 10/05/2008 I drilled and fitted all of the copilot side together on the bench
