The rudder pedals had been removed to allow for painting. I took this opportunity to repaint the rudder petals since some rust areas had started to break through the paint.
The pedals were re-installed. The bolt that connectes to the outside wall was installed with loktite.
The bolt and nut that connects the rudder pedal to the brake cylinder has a standard rotating action. Due to this, I have listed a punch list item to install a wired locknut to allow for smooth operation without the risk of rotating the nut loose.
