Brief Description: Installing the Master Brake Cylinders
This is a mod from the plans since I am using Dennis Ohlmans rudder pedals, I am using lay down brake cylinders from Matco rather than the vertical cylinders called out in the plans. I Layed down 4 plys BID under the location of the brake cylinder pivot point to provide the necessary support.
