08/22/2007 I trimmed the foam at the TE. I filled in the holes in the foam, micro'd the surface, and layed up 30° UNI in alternating directions. I peel ply'd the LE where the UNI was overlapped. I had to remove the elevator from the table to work on the LE. I filled the TE with micro and peel ply'd. 08/23/2007 I trimmed and sanded the TE to fit. I also sanded down the whole skin to remove small bumps and joggles.
