In addition to the equipment that was removed, I decided to install blind nuts on all of the equipment on the inside of the firewall that would have bolts and/or nuts covered up by the insulation blanket and liner. The only piece that still has bolts that will have to protrude through the liner is the fuel pump. The list of equipment that was removed and reinstalled with blind nuts is below.
