Michael's Cozy Web Site
Date:  4-18-2020
Number of Hours:  5.00
Manual Reference:  Step 8
Brief Description:  Cockpit Interior Paint
The Instrument panel had been modifed to inlcude the air vents. The piloit side vent partially interfered with the IP attachment flange to the fuselage. This was trimmed to allow a good fit. A few days earlier, a bed of micro was set on the IP around the flange location for the vent to raise the flange above the fuselage attachemnt.This worked out fairly well.
I did discover one unforeseen problem that will require attention. The canopy latch handle interferes with the air vent. I will likely need to tim the handle to allow full function.
The front hing brackets for the canopy were re-installed and torqued to 25 inlbs.
The radio stack support on F22 were installed.
The ADSB-In antennae was mounted in the nose on the previously attached flanges.
The air cylinder attachment for the font hinged canopy was re-installed.
