GA Aerospace’s Web Site
Date:  3-17-2021
Number of Hours:  0.80
Brief Description:  SL-00009 Compliance
03/17/2021 .80 Hrs
The 25-pin d-sub labeled “HIC” on the Common Harnesses was disconnected from the
AV-60009 HIC Connector Module.
The backshell was removed and Pin 14 and Pin 15 located..
Using the extraction tool was removed the WHT/BLU and WHT wires and their pins
from the Pin 14 and Pin 15 locations in the 25-pin d-sub connector.
The WHT wire and pin was inserted into the Pin 14 position and the WHT/BLU
wire and pin was inserted into the Pin 15 position.
The backshell was reinstalled and the 25-pin d-sub was reconnected to the HIC Connector
Module.
