GA Aerospace’s Web Site
Date:  3-4-2020
Number of Hours:  2.22
Brief Description:  42MiS/U-23
03/03/20: 0.55Hrs
1: The first and sixth rivet on the bottom of the brace were removed and re-riveted with HW-0004s.
Worked on step 2.
03/04/20: 1.67Hrs
2: The fuel sender and spar pin switch wires were routed through the bushings in F-01224-L-1, F-01204F-L-1,and F-01204G-L-1.
3: The spar pin switches were routed further through the snap bushings in F-01204B-L-1 and F-1204C-L and finally crimped.
4: The spar pin switch wires were connected to NO and COM on the switch mounted on the left side.
5: The fuel sender wires were routed through the brace, passing through both HW-00004, then they were secured with tie wrap.
6: The fuel sender wires were trimmed and crimped.
