08/21/19: 1.66Hrs 1. The left hand hold was bent. The wing tip bottom skin and the hand hold were riveted, but the tip rib will have to be replaced.
11/28/19 0.66Hrs 2. W-1213-L Tip Rib was riveted to the rear spar. The W-1204G-L Hand Hold and W-1204C Wing Tip Bottom Skin were riveted to the wing. 3. The W-1204B and the W-1204A-L were riveted 11/29/19 8.5Hrs 4. The W-1204F-L was riveted to the W-1204-L and W-1204B.The tip of the Rear Spar Assembly was filed to ease fit between the flanges of the Aft Wing Tip Rib.
12/02/19 4Hrs 5. The W-1204E-L was fluted so it could matched the outboard edge of the W-1204-L then it was riveted to the wing tip fwd skin and W-1204F-L.
