Brief Description: *** 12A-04 pending final assembly
1. MM on the installed equipement list table. H-STAB FAIRINGS was added to the item column and checked as installed. 1.06lb for weight, 235.324 in for Location/arm and 249.443 in-lb s movement onto the line of H-STAB FAIRINGS. POH on the optional equipment list table. H-STABL FAIRINGS was added to the item column and checked as installed. 1.06 lb for weight, 235.324 in for Location/arm and 249.443 in-lb s movement onto the line of H-STABL FAIRINGS
