GA Aerospace’s Web Site
Date:  3-29-2021
Brief Description:  36iS/U-12
1. The pilot holes in the U-00005A-1 were measured, marked and drilled.
2. The hatched areas were removed.
3.The U-00006C-1 was remporally reinstalled to the U-00006A-L-2 & -R-2 witg the indicated hardware, then the U-00005B was attached to the U-00005A-1 with #8 screws.
4. The fit was correct for the U-00005A-1 and U-00005B.
5. Two pilot holes near the top center were match-drilled with an extender #40 bit.
Each hole was clecoed.
6. The U-00005B was match-drilled #40 to the U-00005A-1 at each dimple in the U-00005B.
7. Each hole in the U-00005A-1 and U-00005B were final-drilled #19.
The U-00005A-1 and U-00005B were disassambled and the U-00006C-1 was discarted.
